- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Extend both secure and guest SSIDs from R7300DST
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a R7300DST package, which consists of a DST Router and a DST Adapter (which I understand uses powerline technology). I have the router set up to generate a secure SSID and a guest SSID. However, I can only get the DST adapter to generate an extension of the secure SSID. Is there any way to make it also extend the guest SSID? If the DST adapter cannot do this, what are my options? Could I install an extender (such as N300, AC750, etc.) in range of the router and set it up to detect and extend the guest SSID? I might have to run an ethernet cable from this extender into a powerline adapter such as a PL1000/PLW1000 pair to get around a thick concrete block wall. I'd appreciate any suggestions or alternative approaches.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Extend both secure and guest SSIDs from R7300DST
It's unlikely that the DST adapter can extend the guest SSID. An extender should work.
