× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Extended is blocking XBOX NAT
Aarontography
Follower
2 days ago,my XBOX NAT started showing "Getting info".And doing a NAT test gave a "can't get a teredo ip"from the XBOX.When I connect to the main router,and even my phone,it shows open.And when I connect my desktop to the extender,and login to XBOX settings,it shows open NAT.So for some reason,the extended started blocking my XBOX from the NAT,but it has internet access.
Any ideas?
Model: EX2700|N300 WiFi Range Extender Essentials Edition
Message 1 of 2
Christian_R
NETGEAR Employee Retired
Re: Extended is blocking XBOX NAT
Hello Aarontography,
You may have to port forward the IP address of the extender and the xbox on the router. I would also check for a firmware update on the extender and factory reset to run through the setup assistant again.
Christian
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 688 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
