- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Extended net don't accept router's wireless key
- Mark as New
- Bookmark
- Subscribe
- Permalink
My extended wifi-net don't accept the wireless key used by the 'base' net.
Need Your help!
From real winter in Sweden // Sven
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Setting the Security Mode to WPA PSK seems to do the trick. Now I have an extended wifi and with some security.
Creds to you for the support // S
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Extended net don't accept router's wireless key
Hi @Svelen,
Please cross check the password which you are trying during setup. Also, make sure access control/MAC filtering is turned OFF on your main router. If both are done, try changing the channel on router which should resolve the issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for your input.
BUT the solution(?!?!) seems to be to switch off any security option, neither WEP or WPA is accepted.
There must be an alternative to no security at all! // Sven
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Svelen,
Extender support WEP/WPA as well as WPA2 securities. Also, if access control/MAC filtering is enabled on router, you need to add virtual MAC address of extender to the access control/MAC filtering list and then try setting up the extender which should work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What do you mean by control/MAC filtering? I see no such possibilty on my router.....
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
technicolor TG799TSvn v2
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Svelen,
Below link will explain about access control of your gateway and to check if it is enabled or not.
https://www.manualslib.com/manual/712507/Technicolor-Mediaaccess-Tg799vn.html?page=113
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
