× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Extender (EX7000) can't see all 5Ghz networks
DrDoogie
Hi folks
Just received my EX7000, posting here until the unit gets its own forum:)
The extender is connected to a Netgear R8000, a router with 2 separate 5 ghz radios in addition to a 2.4 ghz radio. The problem is that my EX7000 only sees one of the 5 ghz radios, inf fact the one with lowest gain. All our family's phones, tablets etc. can see all radios and connect without problems, only the EX7000 is blind......Tried resetting both router and extender with no luck, latest firmware installed on both units. Any suggestions out there?
Regards Dr.Doogie
Message 1 of 4
Fairytail
Virtuoso
Re: Extender (EX7000) can't see all 5Ghz networks
The second 5Ghz are using non dfs channels which the extender might not be supporting that is why it will not detect it.
Message 2 of 4
DrDoogie
Thx for answering! It turns out youre almost right, except that the extender will not detect dfs channels. Non fds works great, but one of the radios only provide dfs.......
Message 3 of 4
Ohboy108
I was having an issue where my EX7000 extender didn't see or connect with my 5GHz network even if I entered it manually.  Spend hours with tech support, returned unit which they said was defective and bought another sample but it had the same problem.  I finally found this KB which solved the issue. http://kb.netgear.com/app/answers/detail/a_id/25057/~/why-can%E2%80%99t-i-find-my-5ghz-existing-netw...
 You're correct ... you have to use a non DFS channel.
But why couldn't tech support know that.  Why is that info not in the instructions.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 5987 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
