× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Extender EX7500 no longer supported by Nighhawk X10
Lbray812
Follower
I bought a nighthawk X10 Ad7200 a little over a year ago. With this I purchased the range extender EX7500. They worked fine together. After a recent firmware update of the X10 the app says the range extender is no longer supported. If this is truly the case and they cut off my support “expired” then what am I supposed to do?
Thanks all in advance
Model: EX7500|AC2200 Nighthawk X4S Tri Band WiFi Mesh Extender
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Extender EX7500 no longer supported by Nighhawk X10
Can you give more detail on what you mean by not supported? is it still working with the router?
DarrenM
Message 2 of 2
Discussion stats
  • 1 reply
  • 414 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
