- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Extender e2700
- Mark as New
- Bookmark
- Subscribe
- Permalink
My extender was working fine until recently it no longer receives internet. The lights are on the extender, it shows as a WiFi network on my devices, but when I connect to (my network)_ext WiFi network, I do not have internet to my connected devices. This is a new problem and nothing else has changed with my home internet. I have tried restoring factory settings, re-connecting the extender multiple times.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
No, for setup the laptop doesn't need to be online. It just needs to be connected to the internet. Thats why I usually recommend disabling the wifi, so the laptop doesn't default back to the wifi connection during setup
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Extender e2700
What router do you have?
Are you setting up using wps or using the installation assistant?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Extender e2700
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Extender e2700
try factory resetting it and then reinstalling using the installation assistant.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Extender e2700
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Extender e2700
during the setup, connect the pc/laptop to the extender with ethernet and disable the pc/laptop's wifi so it can't default back to the wireless connection.
Again, start with it fresh. Push and hold reset for 7-15 seconds. Then use the assistant. Make sure not to use WPS
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Extender e2700
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Extender e2700
