× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Extender is connected to Router and devices are connected to wi-fi - but wont connect to internet
martynrushin
Hi
I'm hoping for some help, because this is driving me mad.
I've have followed all the instructions, and the range extender is located within good reach of the router, and the devices are located in good reach of the extender - all lights are green.
All the devices I attempt to the extender locate the signal which shows as a strong signal on all the devices I have tried. I can easily connect the devices to the wi-fi signal provider by the extender, and it shows as connected (so far I have tried on 2 different Amazon devices, 2 different Samsung phones, as well as a Lenovo laptop.
Regardless of which device I try and regardless as them showing as being connected to the wi-fi with a strong signal, I can't get access to the internet on any of them. They all show their own variation of the same "check your internet connection status" message.
Help??? I'm going insane.
Many thanks
Martyn.
Model: EX6150|AC1200 WiFi Range Extender
Message 1 of 4
DarrenM
Sr. NETGEAR Moderator
Re: Extender is connected to Router and devices are connected to wi-fi - but wont connect to inte...
Hello martynrushin
Do the extenders have a separate wifi name that is different than the main routers name?
DarrenM
Message 2 of 4
martynrushin
Hi Darren
The EXT name shows as the same as the router, so a complete mystery to me.
Message 3 of 4
DarrenM
Hello martynrushin
I would try to factory reset the extender by holding the reset button for 10 seconds then you should be able to do the setup again and see if that corrected the issue also make sure your router and extender are using the latest firmware.
DarrenM
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3655 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
