- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Extender no longer visible
- Mark as New
- Bookmark
- Subscribe
- Permalink
My extender is no longer visible on my network tried everything I can think of reset a number of times. All the boxes to broadcast it over the network are ticked but just cant find it on any device.??
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Extender no longer visible
Did you set it up as a mesh network?
If so, it uses the same ssid as the primary router.
You can log into it and check the ssid settings
- Mark as New
- Bookmark
- Subscribe
- Permalink
I believe so and yes it did show with the same detail as the main router but with Ext on the end so you could tell it apart. Now I just cant see it on any device.??
- Mark as New
- Bookmark
- Subscribe
- Permalink
Maybe the ssid was changed?
If you hardwire into the ex8000, can you access it via the browser?
What does it show on its status page?
