- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Extender will not let me log in when I updated firmware and had just logged in
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was noticing an issue with part of my security system which is connected through wi-fi. While troubleshooting I realized there was a firmware update for my mesh extender. I attempted to update it through the app but it would not let me. I entered the IP address and it requested a log in but password/username did not work. I selected the forgot password/log in option. It asked two security questions which I answered, it gave me my log in and password. I entered them and it prompted me to update firmware. I updated and as soon as it finished it asked me to log in again. Entered the previously given information and it said it was invalid. Clicked the forgot prompt again and it asked the same questions, answered them again and it said the answers were wrong. tried them with different letters capitalized, nothing. Tried entering the stock admin and password log in as if it had reset, nothing. Entered the log in for my netgear account, nothing, now it won't even offer me the "forgot username and password option" even though it keeps asking the same questions when I did.
I did a factory reset on my mesh extender, held the button until the power led flashed amber, let it completely reboot. Followed the basic steps for connecting the mesh extender to my wifi, it shows it's connected to my network, but still won't let me log in following the IP address prompt. Also it still showed it on the current firmware (not a tech genius, I assumed it would reset the firmware). I need to get this sorted so I can make sure my camera network is 100%, please advise.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Extender will not let me log in when I updated firmware and had just logged in
A couple things that I'd try.
1. hardwire a pc/laptop into the extender. See if a direct connection helps.
2. passwords/login are case sensitive. login: admin password: password all lower case. If you changed it, make sure your careful about the capitalization
3. if you have any password managers, disable them. I've see password managers overwrite the password
4. If you installed with WPS, factory reset the extender again and re-run through setup using a hardwired in pc/laptop and the installation assistant. Tends to go the smoothest.
