martyk01
Oct 12, 2015Follower
Extending Wireless Range
I want to extend the range of my wireless to cover outside my house, on one side about 50m to my garage and on the other side about 15m to an outdoor entertaining area.
The current wireless modem sits in one corner of the house, direct line of sight to the shed with just a window in the way. I can just get 1 bar signal outside the shed (colourbond walls) but nothing inside the shed.
On hte otherside the signal has to go through two mud brick walls. Immediately outside the house I still get 1 - 2 bars but a few metres away it rapidly drops to nothing.
Can someone suggest the most appropriate product I should look at?
Thanks
Marty
Hi martyk01,
If the locations are all within the same electrical wiring then consider Powerline:
http://www.netgear.com/home/products/networking/powerline/
Please also see WiFi extenders and run a comparison for your requirements:
http://www.netgear.com/home/products/networking/wifi-range-extenders/
These can be setup as:
router ---(wire)---extender [access point mode] - - - (WiFi) - - - devicerouter ---(wire)---extender [access point mode] ----(wired)---device
or
router - - - (WiFi) - - - extender [extender mode]- - - (WiFi) - - - device
router - - - (WiFi) - - - extender [extender mode] ----(wired)---device
1 Reply
- nhannNETGEAR Employee Retired
Hi martyk01,
or
