- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Failed Firmware Update WN3000RPv3 Wi-Fi Range Extender
- Mark as New
- Bookmark
- Subscribe
- Permalink
I set up my friends booster yesterday, everthing was going well then it asked me to do a firmware update. After doing this, I can't connect to the booster and the power LED just flashes green.
The loading screen during the firmware update got most of the way round before the web page dropped out and showed "no connection" and the power LED was amber. I left it for all day but there was no change, so I assumed the firmware update had failed as it was only meant to take "3 to 5 minutes". Tried to reset it and now the pwoer LED just flashes green.
Was hoping to flash the firmware, mayve via tftp, or roll back etc?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Failed Firmware Update WN3000RPv3 Wi-Fi Range Extender
You can flash the firmware via tftp. here's the procedure for how.
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
here's the support page for version 3. it'll have firmware, manual, etc.
https://www.netgear.com/support/product/WN3000RPv3.aspx
good luck!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
Thanks for this, I am trying the procedure yo ugave but I get "Connect request failed" after trying the tftp command. It also fails using tftp2 software. Are you familair with why this might be fialing?
Cheers!
