Alcofrybas62's avatar
Alcofrybas62
Firmware update doesn't work WN3000RP
Hi, I am trying to update my WN3000RP (Version 1) but unfortunately it doesn't work. I am Firmware verson V1.0.0.16_1.0.20 and I would like to put this version WN3000RP-V1.0.2.64_1.1.86.chk the update is starting but after 3 bars, I got an message:
"Firmware upgrade failed. Please check your file." I downloaded the file from Netgear support page.
So what can I do?
I already try a hard reset.
Thank you in advance ;)
  • Hello,
    Sorry for the late feedback. I enter the wrong device reference ....................
    Thank you for the quick answer.
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi Alcofrybas62,
    Welcome to the community!
    1. Please make sure of the version number of the extender (found on the UI or device itself).
    2. The firmware download page for the version 1 does not list V1.0.0.16 as one of its' previous firmware.
    Dexter
    Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi Alcofrybas62,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
      • Alcofrybas62's avatar
        Alcofrybas62
        Hello,
