× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Firmware update
jdporcelli
Follower
Firmware update
Started firmware update,couldn’t finish,now can’t get internet
Model: EX8000|AC3000 Nighthawk X6S Tri Band WiFi Mesh Extender
Message 1 of 2
Guru
Re: Firmware update
What are all the leds lights doing? color/blinking/solid?
And the power lights, what color is it and solid/blinking?
Have you tried a factory reset? push and hold reset for 7-15 seconds while powered on?
you might be a candidate for tftp recovery.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 317 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
