× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Force WNHDE111 link speed
noisey
I have a WNHDE111 connected to a DG834GT using a Cat5e cable. The link auto-negotiates to 10Mbps instead of 100Mbps. When I connect my laptop to either device, the link auto-negotiates to 100Mbps correctly. Does anyone know a way of forcing the link speed to 100Mbps full duplex instead of relying on auto-negotiation?
Message 1 of 3
jmizoguchi
Virtuoso
Re: Force WNHDE111 link speed
only way is telnet in and if you can tweak it.. other than that you will not able to change the auto-negotiation
Message 2 of 3
noisey
Yes, I'd got as far as telnetting in, but I need to know where to go from there. I came across this article which suggests how to force the connection to 100Mbps, but that's not for the T model which must have a different chip (/proc/sys/dev contains ath/ and wifi0/)
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3742 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
