- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Front Flashing white, and power flashing red
- Mark as New
- Bookmark
- Subscribe
- Permalink
For the past week, my extender stopped working. The front lights flash white and the power light in the back flashes red. Theres nothing in the manual about the issues im having.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Front Flashing white, and power flashing red
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm having this same issue. I've had it unplugged about a week or so until I could deal with it. I plugged it back in tonight, green power light came on briefly, then went back to flashing red with all front lights flashing white. I tried a week or so ago to reconnect but nothing happened. Tried resetting then and tonight, holding the reset button about 10 seconds and nothing changed with the flashing lights.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you ever get resolution? I have same issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would contact NG support about this:
https://www.netgear.com/mynetgear/registration/login.aspx
@HR00 wrote:
I’m having the same issues and can not find my manual. I have unplugged and reset many times with no luck
- Mark as New
- Bookmark
- Subscribe
- Permalink
i had the same problem and could not find anyhelp online. of course netgear refers you to this community instead of helping you because ive had it greater than 3 months. RIDICULOUS. anyway i did get mine working again.
I noticed that when i plug it in the lights in front flash white and the light in back starts out green when you first plug it in then within 30 seconds starts flashing red. after several days of troubleshooting, trying stuff and giving up, i decided to give it another try. RIGHT after i plug it in, While power button was still green (before turning to red) I quickly inserted a paperclip into the reset button and held for 5 seconds to reset ( this did not previously work when the power light had already switched to the red flashing light). this time it did behave differently and eventually reset where only two of the lights on front went to white. then I was able to reset up my extender as if it were new (press the wps button on it and my router) now it is properly operating again.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
