× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
HELP I CANT GET ON MYWIFI
BrendaC1934
Follower
BECAUSE IT SAYS IM NOT LOGGED IN WHEN IM TRYING TO SET UP AS NEW someone fried my ac2200 nighthawk because it turns on but does nothing so I am trying to retro back to my ex 7300v2. To set it up it says to go to mywifiext but every time I go I get a screen that says I’m not connected to the extenders wifi network. But I am trying to figure out how to set it up as new because it is on but nothing is happening. I am a technical idiot. Can someone please help? I have no WiFi at all without one of them.
Message 1 of 2
Guru
Re: HELP I CANT GET ON MYWIFI
1. you're setting up the ex7300?
2. did you factory reset it first to ensure its not already connecting? Push and hold reset for 7-15 seconds while powered on.
3. during setup, if you're on a mac or iOS device, make sure icloud relay and private mac/ip address are disabled
4. did you try setting it up using WPS?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 334 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
