Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Have WNDR4500 -- need recommendation to add Extender
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-12-19
02:15 PM
2013-12-19
02:15 PM
Currently I have a WNDR4500 and wish to add a full speed extender to replace an old "G" 'print server' extender.
What is the best solution? Another WNDR4500 or a purpose build extender?
a) take full advantage of the WNDR4500 bandwidth on both channels?
b) Least cost for a full featured device that does the above and PERHAPS the following:
c) Optional: Ideally I would like more than 4 Ethernet ports on the extender but that is not critical since I can purchase (another) hub.
It is my belief that a WNDR4500 would do this, but that there might be a cheaper solution.
Please offer your advice.
HerbM
HerbM
Message 1 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-12-26
12:57 PM
2013-12-26
12:57 PM
Re: Have WNDR4500 -- need recommendation to add Extender
If you want to take a full bandwidth same with WNDR4500 then I suggest you purchased a exactly the same router and set it as an AP.
Message 2 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-12-26
01:22 PM
2013-12-26
01:22 PM
Thanks. I needed that confirmation that it would work as an access point for this purpose and that there was (likely) no better choice.
Do these actually USE both channels to improve speed or just one at a time?
(Looks like I am going to buy a Powerline 600 if I can't figure this stuff out pretty quick.)
Message 3 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-12-26
02:29 PM
2013-12-26
02:29 PM
Use different channel if using Ethernet cable or power line device to connect 2nd 4500 as ap mode
Message 4 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-12-26
03:04 PM
2013-12-26
03:04 PM
If you're referring to 2.4Ghz and 5Ghz then the answer is YES.
Message 5 of 5
Announcements
