- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Having trouble connecting the extender to home network.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Trouble connecting extender to home network- get as far as trying to “www.mywifiext.net” and can’t connect to NETGEAR Ext. Using IOS on iPad and log in with “www.mywifiext.net.local. Can,t get results using either login. Any help?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Having trouble connecting the extender to home network.
> [...] trying to "www.mywifiext.net" and can't connect to NETGEAR Ext.
"can't" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
I'd expect "www.mywifiext.net" to work only if your (unspecified)
computer/device is connected to the extender, not if it's connected to
your (unspecified) router.
> [...] Using IOS on iPad and log in with "www.mywifiext.net.local.
I would not expect "www.mywifiext.net.local" to work in any case.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read.
Note, too, that there's a specific forum for extenders:
https://community.netgear.com/t5/x/bd-p/home-wifi-range-extenders
- Mark as New
- Bookmark
- Subscribe
- Permalink
To reconnect your NETGEAR WiFi range extender via Ethernet:
- Connect your range extender to your computer with an Ethernet cable.
- Launch a web browser on your computer.
- Type http://mywifiext.net into your web browser’s address bar.
- Press Enter or click Search.
The login page displays.
For troubleshooting help, see I can’t access www.mywifiext.net; what do I do?. - Enter the username and password that you chose during set-up.
Note: The default username is admin and the default password is password. The username and password are case sensitive.
To recover your password, click the Username & Password Help link.
To reset your login credentials, see How do I perform a factory reset on my NETGEAR range extender?. - Click LOG IN.
- Select Setup > Wireless Settings.
- Under Security Options, verify that the value in the Password (Network Key) field matches your router password.
If the password does not match, change it to your router password. - Click Apply.
- Reconnect your WiFi devices to the extender.
Check your IP 192.168.1.1 or 192.168.0.1
