Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Help -New Router killed extender use
- Mark as New
- Bookmark
- Subscribe
- Permalink
2016-08-03
09:31 AM
2016-08-03
09:31 AM
My range extender worked great for 2+ years.
THEN I changed routers.
I've tried the factory reset - I've tried connecting an ethernet cable to the extender - every method i've found on line to get it to talk to my new network - Nothing works.
Does anyone have a suggestion - or better yet a foolk proof method?
thanks!
Model: EX2700|N300 WiFi Range Extender
Message 1 of 3
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2016-08-03
01:01 PM
2016-08-03
01:01 PM
Re: Help -New Router killed extender use
Io ho un problema simile. Mi connetto a mywifiext.net e avvio la procedura di collegamento all'access point, sembra procedere tutto bene ma alla fine viene sempre fuori un errore che non permette di finalizzare la procedura.
L'access point è un plw1000. Col vecchio av200 nessun problema...
Message 2 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2016-08-05
01:31 PM
2016-08-05
01:31 PM
Hello rcsimpson
Make sure you are holding the reset button for 10 seconds when doing a factory reset also try changing the wireless channel on the router.
DarrenM
Message 3 of 3
