veeja1972's avatar
veeja1972
Follower
Nov 15, 2013
HomeNet Manager
I have been using this program called HomeNet Manager to run my network. It lets me see all the devices on my network and protect my network from unwanted guests. Anyway I was wondering if anybody knows if this is compatible with the newest Netgear routers? I want to make sure that if I upgrade my hardware this HomeNet Manager product still works. You can find information on the program a this link:
http://www.homenetmanager.com
Any help would be appreciated.
-Anna
1 Reply
  • If you are using other brand router it would not different than any other router brand you would use.
    Software likely to be using standard network protocol to scan your network. I don't see any issues when you are going to third part application. I think your question may should be asked at http://www.homenetmanager.com/.
    They probably would say it will work fine
