× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Hooking up ps4
Rod4823
Hooking up ps4
Hi i have the AC 1200 A6210 wifi usb adapter trying to use on ps4 wireless ly and cant figure it out
Message 1 of 6
Guru
Re: Hooking up ps4
probably because its not compatible.
under "system requirements" for it:
System Requirements
• Intel® Pentium® class PC
• Best performance with USB3.0; compatible
with USB1.1, USB2.0
• Microsoft® Windows® 7, 8, 10, XP, Vista® (32/64-bit)
Message 2 of 6
Rod4823
Re: Hooking up ps4
Figured idk how to get a stronger signal
Message 3 of 6
Guru
Re: Hooking up ps4
Stronger signal to the ps4?
What router are you using?
Have you tried using a wireless extender?
Or using powerline?
Or using a moca adapter? (ethernet over coax)
Message 4 of 6
Rod4823
Re: Hooking up ps4
Its a att router this is first  thing i tried my router is a few rooms over and i loose signal alot
Message 5 of 6
Guru
Re: Hooking up ps4
I would investigate some of the potentials I listed above.
Message 6 of 6
Discussion stats
  • 5 replies
  • 1576 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
