× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
How can I find firmware version on EX8000?
dbooksta
Follower
How do I find the current firmware version on this device?
I went to "Firmware Update" and tried to check for an update online, but it has now hung for 20 minutes saying, "Checking for a new update. This may take a minute..."
Model: EX8000|AC3000 Nighthawk X6S Tri Band WiFi Mesh Extender
Message 1 of 3
Accepted Solutions
Dretlaw
Initiate
Re: How can I find firmware version on EX8000?
You can also find it under the Status section of the extender when you first log in to the device.  I also clicked on "Check for Update" and it just keeps searching and searching and searching until it logs me off for inactivity.  Not very happy, but it is set to update automatically.
Message 3 of 3
All Replies
DarrenM
Sr. NETGEAR Moderator
It should display the firmware version in the top right when you log into the extender.
DarrenM
Message 2 of 3
Dretlaw
Initiate
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1337 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
