× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
How do I add a second mesh extender
wainfeld
Follower
How do I add a second Nighthawk X4 mesh extender?
Message 1 of 2
Guru
Re: How do I add a second mesh extender
Try powering off the first one that you setup, then add the 2nd one. once its added, try turning the first back on.
I'd advise against daisy chaining them.
Daisy chain: router---->extender----->extender
use them in star configuration
Star: Extender<-------router-------->extender
I also usually advise people to use a full mesh system if you're needing more than 1 extender. they tend to be faster and more stable.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 542 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
