smark22008
Feb 06, 2021Follower
How to Setup Netgear N300 Wifi Range Extender
You can install a Netgear range ext via two methods: Manual method and WPS method. Let’s discuss both the methods one by one.
Learn how you can setup your Netgear N300 Wifi Range Extender
Netgear N300 booster Setup: Manual Method
This method of Netgear booster setup is also known as web browser setup. Follow the instructions given below to set up your device:
- Turn on your Netgear N300 range ext by plugging it into an electrical outlet.
- Connect the booster and your WiFi device.
- Launch the network manager and connect to Netgear_ext.
- Open any web browser of your choice.
- find to the default mywifiext login web page.
- Create an account if you don’t have already.
- Choose the network you want to extend.
- Click on the next button.
- At last, click on the finish button.
Kudos! You have successfully completed the new N300 booster setup. Now, you are free to place your Netgear range ext anywhere you like.
How to Set up Netgear Range Ext Using WPS Method
WiFi Protected Setup or WPS is the easiest way for Netgear N300 booster setup. All you have to do is just go through the below-given steps:
- Firstly, make sure that the booster is powered on.
- Find the WPS button on your device and press it for some time.
- Push the WPS button given on the existing router.
- The LED light will turn solid green showing that the router has configured with the booster properly
- For dual-band range booster, repeat the same procedure.
- Finally, connect to the booster’s network and use the same passphrase as that of the network of your router.
- You can check the WiFi booster manual for the default username and password.
- Thus, your Netgear range ext has set up. Now, connect your WiFi devices and enjoy seamless internet connection all over the house or workplace.
In case you still can’t set up your WiFi range booster after reading the instructions given here, feel free to get in touch with our expert technicians.
No RepliesBe the first to reply
