- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
How to connect to NETGEAR - Nighthawk X4 AC2200 extender after it's on the network
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a netgear nighthawk AC2200 and connected to the network. It is broadcasting my 2.4 but I didn't have my 5hz broadcasting. I now have 5hz broadcasting but I'm not able to connect to the nighthawk via the app to have it extend the range of that wireless.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: How to connect to NETGEAR - Nighthawk X4 AC2200 extender after it's on the network
1. what actual extender is it? AC2200 is a speed, not a model.
2. what router is it connected to?
3. is it setup using its mesh configuration (same ssid)?
4. What method of setup did you use? WPS or the installation assistant?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Model:EX7300-100NAS
It is connected to my 2.4 wifi on extender mode
Yes
I used the Installation assistant. The Nighthawk App.
When I setup the extender I didn't have the 5hz enabled, but now do. So in the setup I had skipped extending the 5hz but wish to now. I'm not sure how to reconnect to the extender. If I use the app it doesn't find it (since it's looking for the wifi it puts out before you have it mesh). Is there an IP it is assigned I can connect to? Or a why to just reset it to factory so I can just go through the app again and extend both 2.4 and 5?
- Mark as New
- Bookmark
- Subscribe
- Permalink
the EX7300 has a fastlane mode where it can use the 2.4ghz as the router---extender communication link. But my understanding of that device is that you'd need a 5ghz network to connect it to to extend.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Factory reset it. Push and hold reset for 7-15 seconds while its powered on.
then just follow the installation guide.
