- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
How to create independent network
- Mark as New
- Bookmark
- Subscribe
- Permalink
I want to use the device to create a separate network for my guests. In normal use, a pc connected to the extender can see another pc connected to the original router. I do not want that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: How to create independent network
If your original router has a guest Wi-Fi network, you should be able to use the extender to extend that network. If you are currently using your extender to extend your main Wi-Fi network, then you'll need to buy a second extender for the guest network.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for such a quick response. I am looking at the configuration of my router and it does not have a guest WI-FI network.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Most routers have a guest network. What model is your router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Compal Broadband Networks CG7486E version firmware 5.510.5.9
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your router appears to not have a guest network.
