- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
How to extend wifi using two routers?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi guys,
I have a house and a granny flat at the back. I have the internet connected (Optus Cable), the speed is fabulous however the granny flat at the back can't seem to get signals from the modem/router at the front house. Is there anyway that I can extend the wifi?
Modem/routers that OPTUS uses:
1 - Netgear Cable CM500V-1STAUS
2 - SAGEMCOM F@ST 3864V3 AC
I also have: Netgear Hawk D7000.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: How to extend wifi using two routers?
Hi @soloko2412,
Welcome to the community!
Are all 3 devices being used simultaneously? If so, please provide a diagram of your network for us to provide a better recommendation.
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Dexter,
Thanks for your reply.
I was using the D7000 when I used to have ADSL connection, I recently switched to Cable connection.
Currently, the two modem/router that I have been using are:
I have attached a diagram for you. There's an enthernet port at the granny flat that I used to connect the ADSL modem (when we still had to use ADSL connection) from the main house to the granny flat.
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @soloko2412,
Is there an Ethernet cable running from the main house to the granny flat? If yes, then you can configure the D7000 as an access point as described on page 112 of the user manual on this link.
Dexter
Community Team
