× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
How to supplement a Nighthawk extender
clamarain
Follower
I am using a Nighthawk X4 AC2200 Wifi Range Extender - Model EX7300 - in my home, but it does not give me sufficient coverage. Is there a way of adding a second extender to the existing network? If so, must I purchase the exact same model, or is there a less expensive extender I can use in combination with the Nighthawk? I am using the Windows 10 Home Operating System.
Model: EX7300|AC2200 Nighthawk X4 WiFi Mesh Extender
Message 1 of 2
Guru
Re: How to supplement a Nighthawk extender
You can add a 2nd extender.
just make sure to go:
extender<-------router------->extender
Reason why is the extenders a can end up connected to each other if they're to close togther.
If you have to daisy chain, you might want to set one with its own unique ssid instead of running it as mesh.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 281 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
