- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
How to use EX7000 as a switch?
- Mark as New
- Bookmark
- Subscribe
- Permalink
After reconfiguring my local network I have an unused EX7000. Can I use it as an ethernet switch (only wired, no wifi) ? Are there any specific ports for in and out?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: How to use EX7000 as a switch?
There isn't any in/out ports. So use whichever you need.
Page 30 of the manual goes over disabling the wifi radios
Nighthawk AC1900 WiFi Range Extender Model EX7000 (netgear.com)
but it might be worth leaving them enabled as a backup for other devices. Just make sure they're on a different channel as the primary router to prevent interference.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks. What about the wired connection speed in switch configuration? Does it go over 100Mbps? There are no specs for this configuration. My gateway/network is capable of 400Mbps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The EX7000 has gigabit ports. If they're only connecting at 100mbps speeds, check your cables.
Move the ex7000 right next to the router and connect it with 2 known good 6ft cables (one from router--extender and other from extender---device) and test the speeds.
