× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Hurricane Ian & EX7300v2 — AC2200
Tom606
Follower
After Hurricane Ian rolled through causing numerous power outages, my extender quit. All lights are on, cannot do a factory reset. I'm an old man and do not understand how this new technology works (or breaks). Any suggestions?
Message 1 of 2
Guru
Re: Hurricane Ian & EX7300v2 — AC2200
When the power light is lit up amber, it usually indicates a boot issue/corruption issue. Storms are great at causing this.
You can try recovering it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
If that doesn't work, you might be SOL and if you have other damage to the home, turn it in to home owners as the power surges might have caused issues
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 310 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
