× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
I NEED TO RECONNECT MY EXTENDER TO A NEW WIFI NETWORK SERIAL 4R289C7SA0215
NATLEIGH
hello,im new to this ive just had to upgrade my wifi and now need to reconnect to the extender with the new details but i dont know how ,
Model: A6150|AC1200 Dual Band WiFi USB Mini Adapter
Message 1 of 4
Guru
Re: I NEED TO RECONNECT MY EXTENDER TO A NEW WIFI NETWORK SERIAL 4R289C7SA0215
You posted in the nighthawk section about an extender. And put  A6150 in the signature which is a wireless usb adapter.
What actual extender do you have?
What firmware is on it?
What router are you connecting it to?
go to netgear.com/support/   type in your actual model number and it'll take you to install guides, manuals, firmware.
Current setup: CM2000-> RBE973S-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/100mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 4
NATLEIGH
Hi sorry not very tech,
It's a netgear ac1200 universal pass through wifi range extender
Ex6130
Message 3 of 4
Guru
what router are you connecting it to?
You can always factory reset the extender (push and hold reset for 7-15 seconds while powered on), then follow the new install guide.
it can be found here:
EX6130 | AC1200 WiFi Range Extender | NETGEAR Support
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 371 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
