- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
I Need HELP!!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
I Need HELP!!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: I Need HELP!!!
1. Model number helps. What model is it? firmware on it?
More than likely you either switched a combo device over to modem only or you switched a router over to access point mode (shouldn't have lost wifi if you did this. Without knowing specific model the fastest way to fix it would be to reset it back to factory (hold reset button 7-10 seconds) and reinstall the device from factory. If you get back to us with a model number we can probably avoid the factory reset. Might take you longer though. 🙂
You can go to netgear.com/support/ and put in your model number. It'll have a manual, firmware, and installation instructions for your model.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: I Need HELP!!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: I Need HELP!!!
Are you connecting an extender to a router? Or whats going on exactly with your setup? More details help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: I Need HELP!!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: I Need HELP!!!
If you don't have access to the device (physical access), wifi isn't broadcasting, and you don't have the option of an ethernet connection, you're kind of screwed until you do get one of those. Things that will help when you get those.
1. Model number:
2. Firmware on it:
3. the setup. aka modem---router--extender or modem---router or modem/router combo device
4. what app?
Once you get access, what you've tried to get it working.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: I Need HELP!!!
