× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
I'VE PROBLEM WITH A lUMIA 930
Robyn_ball
Follower
I have a Lumia 930 and a Lumia 920. The second one when I try to connect a WN 604 It's OK, when I try with the first no.
the password is particularly long, 26 characters, but it's the same I use 920, why the 930 does not work?
Message 1 of 2
nhann
NETGEAR Employee Retired
Re: I'VE PROBLEM WITH A lUMIA 930
Hi Robyn_ball,
Try shortening or changing your password on the WN604. Then connect your Lumia 930.
Is your Lumia 930 able to connect to other WiFi networks?
You can also try posting your question on the Nokia Lumia 930 forums, to see if others have experienced the same issue on this device: http://forums.windowscentral.com/nokia-lumia-930/
Message 2 of 2
Discussion stats
  • 1 reply
  • 3017 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
