jimsmith77's avatar
jimsmith77
I can't access the Netgear web site for instructions
I have tried to access the Netgear web site to install my extender manually, using an ethernet cinnection, but am still unable to get connected.
Can anyone help?
  • > I have tried to access the Netgear web site [...]
       Which "the Netgear web site"?  netgear.com?  routerlogin.net?  ...?
    > [...] to install my extender manually,
       What, exactly, is "my extender"?
    > [...] but am still unable to get connected.
       "am unable" is not a useful problem description.  It does not say
    what you did.  It does not say what happened whan you did it.  As usual,
    showing actual actions with their actual results (error messages, ...)
    can be more helpful than vague descriptions or interpretations.
    • jimsmith77's avatar
      jimsmith77
      SORRY, BUT I'D ALREADY SPENT SO LONG ON THIS SITE THAT I WAS GETTING VERY FRUSTRATED. IT'S AN N300 WIFI RANGE EXTENDER, MODEL EX200. I TRIED TO CONNECT TO THE SITE: WWW.MYWIFIEXT.NET. I COULD NOT CONNECT BUT FOUND TRHOUGH A RELATED SITE ON GOOGLE THAT I NEEDED TO CONNECT THROUGH AN ETHERNET CABLE NOT A WIFI CONNECTION. I DID THIS BUT THE SAME THING HAPPENED. I CAN THUS NOT SET UP THE EXTENDER TO WORK WITH MY EXISTING ROUTER. THIS IS THE ACTUAL ERROR MESSAGE I RECEIVED:
      This site can’t be reached ____server DNS address could not be found (ACTUAL ADDRESS REMOVED AS INVALID BY NETGEAR
      • antinode's avatar
        antinode
        Guru
           Shift key stuck?
           "www.mywifiext.net" is not the right place; (plain) "mywifiext.net"
        might be.  (That looks like poor judgement by Netgear.)
           Is that a Netgear product?  Is that really the model number?
        > [...] FOUND TRHOUGH A RELATED SITE ON GOOGLE [...]
           An actual link to that page might be more useful than your summary of
        what it says.
