FeeNom
Oct 15, 2017Follower
I can't connect to the 2GEXT on my wifi extender
Hi, I did the WPS install for my EX6150v2 wifi extender. After the extender was paired with my router, I unplugged it and took it to another location in the house. The power LED, WPS LED and the router link are all green. When I try to connect to the 2GEXT from my laptop, it says Can't connect to this network. I've read the quick start manual several times and I didn't miss a step. Any help would be appreciated.
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello FeeNom
Go into the settings of the extender by going to www.mywifiext.net and try to change the password then try to connect the laptop again with the new password.
DarrenM
