× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
I need to reset my EX 7000 range extender and then set it up on a new network. How is this done?
LauraG
Hello,
I recently had to reconfigure my home network and remove the old network and replace it with a new one.
Do I need to completely factory reset my EX 7000 Extender in order to install it on the new network?
If so, once I've factory reset it, how do I install it onto my new network even though it's not a new extender and has already been registered with netgear?
I'd appreciate any help on this, thanks in advance.
Message 1 of 3
Guru
Re: I need to reset my EX 7000 range extender and then set it up on a new network. How is this done?
You don't need to factory reset to reinstall it but it tends to go smoother.
to reset, simply push and hold reset for 7-15 seconds while its fully powered on.
then follow the install guide found here: https://www.netgear.com/support/product/EX7000.aspx
Message 2 of 3
LauraG
Thank you
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 413 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
