- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Incorrect email during installation of my N300 Wifi Range Extender
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello, during setup the email was incorrectly entered by placing an inadvertant L at the end of the name in the email, so I was able to complete setup as it would not even after resetting the device twice allow me to reset or change to the right email. Is there a way i can get my email corrected?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Incorrect email during installation of my N300 Wifi Range Extender
I believe the WN3000RP uses admin as the username for it's web ui, and doesn't allow that to be changed.
Do you mean that you accidentally registered the extender using the wrong email address? If that's the issue, you'd need help from support to solve this. You do have 90-day technical support, so you this is a new install you can contact them via my.netgear.com.
