Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Install after factory reset - won't stay connected
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-07-08
08:41 AM
2014-07-08
08:41 AM
I've had my extender for quite awhile - a year or more. I had it set up and connected it to my Netgear wndr3700 router and all ran fine, until now.
Nothing can connect to it, and I can't access it through the web browser. I recycled power, and reset the extender to its factory defaults (several times), but only the power led is lit, and it is amber. The wireless connection will appear briefly. Then goes 0. At that time, the power led goes green, but goes back to amber.
I tried to connect directly via lan port, but the computer, when it gets a dhcp setting (if it ever does), loses it after a few seconds, just like the wireless. Although the port led does show up.
I did try using WPS, but that failed as well - pretty much the same symptions.
Is the extender dead?
I've already spent a day trying to solve this, and don't want to waste any more time. I'll lay out the cash for another extender, but I want to make sure this one is really dead.
Any help greatly appreciated.
TIA
ken
TIA
ken
Message 1 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-07-08
09:27 AM
2014-07-08
09:27 AM
Re: Install after factory reset - won't stay connected
disable your WIFI on your pc if exist and try again
Message 2 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-07-08
02:24 PM
2014-07-08
02:24 PM
jmizoguchi wrote: disable your WIFI on your pc if exist and try again
This is actually the same problem as in this thread: http://forum1.netgear.com/showthread.php?t=85994. It didn't show up in the search results, and I just noticed it.
I sent a question into support for this. But, looking at the posts in that thread, nobody there knows what's going on. I would redirect people to that thread.
ken
Message 3 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-07-08
03:32 PM
2014-07-08
03:32 PM
Did you try with WIFI on pc disable if you have one ?
Message 4 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-07-08
04:04 PM
2014-07-08
04:04 PM
jmizoguchi wrote: Did you try with WIFI on pc disable if you have one ?
Yes. I tried every possible combination one could think of.
Read my post (as well as all of the other posts) in the thread I mentioned above . That will describe the problem more thoroughly.
ken
Message 5 of 5
Announcements
