× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Intermittent loss of internet - EX8000
DavidPhilip
I've been trying to run an EX8000 in extender mode with Firmware Version: V1.0.1.238 with a dell laptop (Windows 10) and iPhone SE and I keep having the same issue that the router intermittently completely loses internet connection. The signal strength is good but I go from having ~100Mbps to a lost connection. Restarting the router solves the issue until the next time.
I've reset to factory defaults but the problem recurs. I'm not super technical so I'm wondering if there's an underlying fault or something I can do to get a robust performance
Model: EX8000|AC3000 Nighthawk X6S Tri Band WiFi Mesh Extender
Message 1 of 3
Guru
Re: Intermittent loss of internet - EX8000
what actual router is the EX8000 connected to?
What firmware is on the router?
What method of setup did you use for the EX8000? WPS, the app, installation assistant?
Message 2 of 3
DavidPhilip
It's connected to a proprietary Virgin Hub 3.0. (Googling it says its built by Arris and is known as the TG2492LG-VM)
The firmware is  V1.0.1.238
I used the setup wizard.
Thanks. I appreciate the help.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 986 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
