× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Is the gremlin in my extender?
Kla2
Mac OS/ BTHub6-CF5N
An strange niggle has cropped up with my use of extender that I'm unable to correct. Everything had been work fine until yesterday. Getting connected seemed normal, but then even though my Mac is telling me wifi is connected and Netgear genius says the same thing, all lights on the extender are green, my browsers, Firefox or Safari, will not connect to any links.
When I go back into the room with the main Hub is located, as I'm doing now, everything, is working fine. But I'm unable to work at the end of the house where the extender was in operation. I have twice restarted the HUb, reset the extender to default, reconnenected via WPA. but to no effect.
Any suggestions appreciated.
Model: WN3000RP|Universal WiFi Range Extender
Message 1 of 5
Accepted Solutions
Kla2
Re: Is the gremlin in my extender?
Thanks to all who offered advice. I am now well prepared. I say that, for
the simple rteason that my gremlin appears to have left the scene. As my
extender, no thanks to any of my own efforts, and just as mysteriouly as
the problem presented itself, is working as it should.
But if it starts to act up again, I know where to begin my investigations.
I may be back? Thanks again all. Cheers
Message 5 of 5
All Replies
DexterJB
NETGEAR Moderator
Hi @Kla2,
Welcome to the community!
1. What is the firmware version of the extender?
2. Have you tried going through the manual configuration instead of the WPS method as described on page 8 of the guide here?
3. Does the issue persist with your other wireless devices when connected to the extender?
Dexter
Community Team
Message 2 of 5
Kla2
Unable to discover the firmware of this extender. Not on my spec sheet. Where where should I look? But have been reading about a firmware uprage that might be available. I have gone through the manual configuation without solving the problem and the issue persists with both my Macs. One old and one with fully up to date OS. The extender model does have the letters V1H2 after the model number.
Message 3 of 5
Guru
Log into the web ui.  There should be a status screen that shows it, or you can go into the firmware update screen (which will also show you what you are current running).
There are three somewhat different WN3000RP extenders - WN3000RP, WN3000RP v2, and WN3000RP v3.  They use different firmware.
Message 4 of 5
Kla2
Message 5 of 5
Discussion stats
  • 4 replies
  • 988 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
