- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Is there a way to have 2 completely separate WiFi networks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello!
I use this to share my wifi with my neighbours.
I have no issue with having them on my network the problem is when I go to play something on my TV with a youtube App for example, it just zooms to my neighbours TV!
Ideally I would like to completely isolate them from my own stuff, so I can be on one network and they can be on another and I can't accidentally do stuff like that in the future.
Somebody gave me this wifi extender recently and I am actually using it to give the neighbours better signal from my BT home hub 5(possibly 6) and I was wondering if there was any way at all to completely isolate each wifi connection so they can't pass data like videos from connection 1 ( My phone ), to the extended connection 2 ( Neighbours TV )
Is this possible with this device?
Thanks for reading! Hope I was clear. Cheers.
Twizz
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Is there a way to have 2 completely separate WiFi networks.
What you really need is a router that has the "guest network" feature. That has the network isolation feature you are looking for. Unfortunately BT hasn't put that feature into their routers.
The extender doesn't have that feature either. You could upgrade your home hub with another router that has the guest network feature, and then extend the guest network.
Also your neighbors can access your PCs and any other devices that are on your home network. You need to be careful on security (or be very trusting) when you share your home network.
