×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Login to 2nd router
avalonacreslla
Follower
Login to 2nd router
Im not sure exactly where this should go.
I have a Nighthawk in my house. From it, using DECA ends (as a power/signal inserter) and coax, I have run to a N750 in my garage apartment/office. Its working fine internet access wise, but I need to log into the 750, and cant. When I use the netgear genie, it will go straight into the nighthawk. How do I log into JUST the 750?
Message 1 of 2
schumaku
Guru
Re: Login to 2nd router
Provide some simple graphics on how things are set-up.
Two NAT routers - being side-by-side or in-line - are not a good choice. Management issues, havoc, poor communication options in-house are predictable.
Only one router has to operate as a router, the other should be wired to the primary router LAN port and configured as a wireless access point.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 390 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
