Reply
MAC filtering issue with a B&N Nook reader
kevin0707
Follower
I have a Netgear WNR2000v3 wireless router setup as an access point to a wired router off of a DSL modem. Up until a couple of weeks ago my Barnes & Noble Nook color e-reader had great connectivity without any problems. The Nook will no longer connect and the message it gives me is: MAC Filtering Issue: There seems to be MAC filtering issue with your Wi-FI connection. The message suggests that I (1.)turn off MAC filtering on my wireless access point or router or (2) add NOOK's MAC address to my wireless access point or router. Does any one know how to do this?
Message 1 of 6
fordem
Mentor
Re: MAC filtering issue with a B&N Nook reader
First question - are you using MAC filtering?
If you don't know the answer, then it's probably no, because if you are, you would have had to enter the MAC address of every wireless device on your network, or those would also not connect.
Give a man a fish, feed him for a day
Teach a man to fish, feed him for life.
Message 2 of 6
jmizoguchi
Virtuoso
WNR200 is no access point. It is witless N router
Belongs to http://forum1.netgear.com/forumdisplay.php?f=33
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 3 of 6
Ssavage
I just received a NOOK and cannot get wifi to connect. When I tried to update Netgear I got this message: "This file does not have a program associated with it for performing this action. Create an association in the Set Associations control panel." I have a windows control panel but did not understand how to get to the above. Can someone help me please?
Message 4 of 6
jmizoguchi
Virtuoso
make sure you unzip the folder and upload file
also firmware upgrade usually not necessary but more about wireless setting the route that my need to changes
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 5 of 6
fordem
Mentor
Presumably you're trying to update the router firmware - you can't do it by clicking on the file. That update is done from the router's web interface. Now would be a good time to download and read the owner's manual.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 3299 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
