× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Manually Select Bands MR5100
codeman1287
Does any one have a clue on how to manually select bands ive tried doing it through the web page but no luck was found someone please shed some light.
Message 1 of 4
Guru
Re: Manually Select Bands MR5100
are you talking manually selecting between 2.4ghz or 5ghz?
If so, page 31 in the manual goes over enabling/disabling bands.
https://www.netgear.com/support/product/mr5100.aspx
Message 2 of 4
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Mobile Routers, Hotspots & Modems
Message 3 of 4
codeman1287
no i am talking about the radio band like b2,b5,b12, and so on you can do it on the mr1100 but not the 5100
Message 4 of 4
Discussion stats
  • 3 replies
  • 877 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
