Orbi WiFi 7 RBE973
Reply
Mesh Extender versus Mesh System
markpk
Initiate
I am using a R6700 router in my house, which is about 2500 square feet on 3 floors.   Overall it is performing very well, however once in a while I run into an issue related to a low signal.  I am considering purchasing the EX8000 mesh extender, and am curious about the difference between adding a mesh extender to my existing router versus purchasing a mesh system such as the Orbi RBK50.  Does the addition of the EX8000 to my existing router create a "true" mesh system, or would there be benefits to the Orbi RBK50 over the mesh extender?  I appreciate the help!
Model: EX8000|AC3000 Nighthawk X6S Tri Band WiFi Mesh Extender
Message 1 of 3
Accepted Solutions
Guru
Re: Mesh Extender versus Mesh System
I've used both (ex8000 and RBK50) and it basically depends on your useage.
Does adding the EX8000 make it a "true" mesh system. Not really because there isn't a router controlling the system. Is it close enough that the average home user won't notice the difference? yes. It works well and provided your phone/pc/tablet is new enough, will roam like the orbi system will. it worked great at my place and i'm around 3200sqft. I tried it with an RAX200 and a C7800. Both worked well.
The benefit to the orbi comes if you're going to want more than 1 extender. Once you're needing more than 1 extender, its better to move to a full mush system like Orbi. But 2500sqft should be fine with 1 extender.
Message 2 of 3
All Replies
Guru
Message 2 of 3
markpk
Initiate
Thanks plemans.   That was helpful.   Mark
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1155 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
