yowahaus
Jul 19, 2020Follower
Mesh w/ dual-band router
Hi All,
I have a Nighthawk AC1900 Dual-Band Cable Modem Router but need a ethernet plug (LAN) in another room. Work laptop works significantly better with hard connection than over wifi. Can I add a Home Mesh system to the AC1900 dual-band? If so, how?
Thanks.....
1 Reply
Are you talking a mesh extender or a mesh solution like netgear orbi?
They're a little different in how they function and work.
