× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Model - EX6150. No device is capable of accessing the 2GHz option on the extender
Dylan12345
Follower
Everytime the code is typed in to use the 2GHz setting, it does not alow the device access. This is apparently the option needed to to boost the strength of the signal as the 5GHz is weak.
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Model - EX6150. No device is capable of accessing the 2GHz option on the extender
Hello Dylan12345
Do you happen to have the 2ghz connection named the same as the main router if so you will want to change it. Also do you have fast lane active on the extender if so then you should only be able to use 1 band.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1974 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
