- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Multiple WNDR4000 Routers as APs
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am looking to set up 1 router with 5 or so access points around the house, all attached back to the router via hardwire. I like the look of the WNDR4000 for the router, but couldn't find a good access point to compliment it. I did find the brand new AP from netgear, WNDAP360, but it is quite pricey. If I could just purchase 6 WNDR4000 devices that would be better.
Question:
Can I run the 4000's as access points only? If so, will moving around the house work properly. In other words will the routers (APs) hand off the connection to each other assuming I use the same SSID and security on all APs?
I have been searching for the answer to these questions for a while with no luck. I have seen people use the 4000 as an AP, but haven't seen confirmation regarding the other question.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Multiple WNDR4000 Routers as APs
hook up each one with CAT5 . use same SSID, encryption
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
that is the diagram show isn't it? 🙂
Will wifi work as seemlessly as it would if I used actual Access Points? In other words moving around the house will be seemless?
you can choose to buy AP is your choice.
otherwise makes no difference
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
jmizoguchi wrote: 7 ap with same SSID uses same channel
Thanks for heads up! I just tried it with 3 4000's on both bands and it does work. I used inssider while streaming and watched the status change from 300 to 150 I even tried to find a area where all 3 where at same level and it still worked.
Thanks again:eek:
