×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Multiple WiFI Extenders
Wichitan
Follower
I need to extend my wifi to 2 outbuildings.  Can I use just 1 Powerline Adapter with 2 Extenders or are these available only as a matched set?  If I can, is there a part number for just the Extender?  Running on Win10.  All buildings connected to same electrical panel.
Message 1 of 2
Guru
Re: Multiple WiFI Extenders
Not sure how far apart the buildings are from the main and each other. You might be able to make it work with powerline. But powerline is sensitive to interference.
You can't currently by single devices or a 3 pack that I know of from netgear. But you can mix/match different manufacturer's of powerline devices so long as they follow the same powerline standard.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 2
Discussion stats
  • 1 reply
  • 222 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
