- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
My AC1750 Dual Band WiFI Mesh Extender will not bring up a web page even when all lights show green
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: My AC1750 Dual Band WiFI Mesh Extender will not bring up a web page even when all lights show g
What extender is it? AC1750 is a speed.
What router is it connected to?
What method of setup did you use? wps or the installation wizard?
- Mark as New
- Bookmark
- Subscribe
- Permalink
LYONS REPLY
NETGEAR Model number EX6250
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try factory resetting the EX6250.
Push and hold reset for 7-15 seconds while powered on. the lights should change/flash when held long enough.
then install using the installation assistant.
what happens after following that?
also, keep in mind the EX6250 is a mesh extender. meaning in default setup is uses the same ssid as the router. If there's a different ssid showing up, it might not be yours. It might be a different device simply being picked up.
